Inventor Forum
Section View Properties in iam
7 REPLIES 7
Message 1 of 8
rdyson
826 Views, 7 Replies
Using half / quarter section view, I know how to section CC parts.
How do I NOT section custom parts?
There has to be setting somewhere. Anyone know?
PDSU 2016
7 REPLIES 7
Message 2 of 8
Cadmanto
in reply to: rdyson
You are talking about something similar to the Display Options under "Section Standard Parts" where you can select which groups you want sectioned except this in assembly mode I am assuming.
Or are you looking for something where you can randomly select individual parts that you don't want sectioned in the assembly model.
Either way I am not seeing anything that does this in the model.  If there is I would like to know myself as well.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 8
in reply to: rdyson
I guess you are looking for 'participate in assembly and drawing sections' you find this checkbox in the part environment
tools --> document settings --> modeling tab
i hope this helps!
Message 4 of 8
rdyson
in reply to: Cadmanto
Curtis,
There is obviously some setting that allows / causes CC parts to not participate in sectioning in the assembly environment. (see below)
I was looking for a way to make one of my parts behave the same.
PDSU 2016
Message 5 of 8
in reply to: rdyson
Edit the part you don't want sectioned and uncheck this box in document settings.12-11-2012 8-58-00 AM.png
Message 6 of 8
rdyson
Thanks you! Knew it had to be somewhere.
PDSU 2016
Message 7 of 8
Cadmanto
John,
Thanks for the tip.
It is a shame that this is not built into the actual section command itself, like I have experienced in other softwares.
Where you can select components not to be affected while in the command.
Best Regards,
Scott McFadden
Message 8 of 8
Yes, sure would be nice if you could change this at the assembly level.
