Hello!
I have a big assembly of a scanner and in my drawing i've made a section view and in that section view, the part that are cut disappeared.
I have to do a section view precisely to annotate the position of the part that are cut... Do you know how i could keep the cut part in my section viewe?
Thanks in advance
What version of Inventor?
Service Pack?
Graphics card/Driver?
What if you go to Tools>Application Options>Hardware tab and set to Software Graphics?
RenaudCharles,
Welcome to the forum.
Can you please check to mack sure that your part is set to participate in the section view.
Here are a couple of link that will guide your through the process:
https://www.youtube.com/watch?v=wV7XqzjaRIw
Please send us an update after you have had a chance to review the information above.
Thank you.
The part that disapeared are not in my browser, so i cant check if they are in section representation or slice.
Do you have an idea how i could make them appear in my browser?
Finally, i could make the cut parts appear if i clicked the whole assembly and select ''none'' in the section participation. Though, if i selct a part and switch its section participation from ''none'' to ''section'' it will disappear.The problem is that I want to show the middle of the part and i can't do it when selection participation is on none. Any ideas how to fix this problem?
RenaudCharles,
Is this a Multi-Part Assembly or a Multi-Body Part?
Thank you.
