Greg, here's a tip for the centerline errors you showed in your sample. What I now do, if the part is revolved about an origin axis, is to (in the drawing browser), expand the node for the view, then expand the node for the model in the view. You should be able to then RMB on the origin axes and "Include" them.
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px"
dir=ltr>
"brian r. iwaskewycz" <
href="mailto:biwaskewycz@REMOVETHIS.corefurnace.com">biwaskewycz@REMOVETHIS.corefurnace.com>
wrote in message
href="news:6204435@discussion.autodesk.com">news:6204435@discussion.autodesk.com...
This could easily be solved with a simple
checkbox inside of the "Edit Section Properties" dialog - see
attached...
brian
r. iwaskewycz
style="FONT-FAMILY: Verdana; FONT-SIZE: 14pt">inventor
specialist
href="http://www.corefurnace.com/">core furnace systems
ah, that would be another good addition. But what if you wanted the cut lines (i.e. wanted the section to crop the view)? There are times I use the section view specifically to "cut" out only part of a view.
dir=ltr>
wrote in message
href="news:6204496@discussion.autodesk.com">news:6204496@discussion.autodesk.com...
Exactly.
brian
r. iwaskewycz
specialist
title="http://www.corefurnace.com/ CTRL + Click to follow link"
href="http://www.corefurnace.c...
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
<c.henry> wrote in messageexcuse
href="news:6204503@discussion.autodesk.com">news:6204503@discussion.autodesk.com...
me for being dumb, why would you want to section that or any part that way,
what would you hope to detail by having the "head" in that view with cut edges
? should that section not be either a full view or just a zero depth slice ?
what happens if you adjust the depth of the section to terminate inside the
"head" ? i understand the lines messing up the machinists out on the floor,
but if you use eithe rof the other methods that is not an issue is it ?
/curious
