Hello all
when using section views, the non sectioned view keeps popping back ( white transparent ) every time I scroll over it, and it makes the section view unusable, How do I change the properties on this?
Untitled1 is what I want, untitled2 is what happens when i put my mouse over it. It is making my eyes twitch.
Thanks.
Solved by symdraft. Go to Solution.
Ok more information.
It happens in an <assembly> but when I edit a <part> in an assembly, the section works properly.
This may not be a normal issue, I may be going about the workflow wrong.
I greatly appreciate the help!
background - I have a concrete structure, and there are aluminum plates. I was trying to place steel beams to hold the aluminum plates up.
I had the assembly open, sectioned the assembly and tried placing the steel beams - which caused this issue ( should have explained what I was doing first )
Now in retrospect, I should have made a new part? for the steel beams to place them?
I have thick skin so you can say it was stupid 😎 - it is what the trials for.
There should be a toggle to turn off the behaviour though.
can you post the IAM along with the IPT files?
Just checking it's not the easy solution.....have you toggled the enhanced pre highlighting yet?
