style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"dhoerig" <I'm
href="mailto:dhoerig@shafervalve.com">dhoerig@shafervalve.com> wrote in
message
href="news:f127718.-1@WebX.maYIadrTaRb">news:f127718.-1@WebX.maYIadrTaRb...
having problems with sectioning an assembly in Inventor version 6 sp1, which I
believe worked correctly in version 5.3. I have a simple round part with
twelve evenly spaced tapped holes (in a polar pattern) and twelve bolts. I
define the section cut to start horizontally thru the bolt at 3 o'clock, to
the center of the part, then at an angle that passes thru the bolt at 10
o'clock. At this point, every looks great. I then "show contents" in the base
view, select all the bolts, and turn off "section" for these parts. The bolts
at the 10 o'clock position and 11 o'clock position no longer appear in the
section view! I expected the bolts to appear in the section view, just not
sectioned. Can anyone else produce the same results? Am I doing something
wrong? Any help would be greatly appreciated. Thanks
"dhoerig" <I'm
message
