"Mark V" wrote in message
news:D3FCE33093E89EA5834E9258050A28C1@in.WebX.maYIadrTaRb...
> Allow me to clarify... I can make a full section thru a part with a
> straight section line, true. I can also make a full section thru a part
if
> i start my section line at 12 oclock, stop at the center and from the
center
> go in any angle greater than 90 deg from the initial segment. in other
> words, a 120 degree segmented section line will give me a full section but
a
> 90 degree segmented line will not. I'd simply like to overtide the
> automatic half section it gives me.
I just did some experimenting, and if you don't create the cutting plane
line at a right angle you can achieve what you are trying to do. After
creating the section, edit the sketch that is created for the cutting plane
line and put in an angular dimension. As long as the angle is greater than
90° you will get full section. You can then delete the dimension. At
exactly 90° IV defaults to a half section, which it should.
Hal Gwin
Mechanical Designer
Xenogen
