I made an assembly, inserted a bolt and saved it to another file for thee modifications i make in the screw.
I try to make a section view with one of the origin planes, but it doesn't make
Solved by pcrawley. Go to Solution.
1. File>Save Copy As
2. When you can't find something - right mouse button (see attached image) (note: you can set section participation by component)
or
for all parts rather than by component - see attachment.
No, not in a drawing the section didn't work, in a part file.
I opened a bolt from content center, saved it to another name and edited the bolt.
In that file i couldn't slice the part, the command view>half section view
I thought I posted in the attached image above?
Tools>Application Options>Assembly tab - Section all Parts.
Oops, now I am confused whether you are in an assembly or part.
Attach the ipt file here that exhibits this behavior.
Try opening the part - Tools > Modeling > "Participate in Assembly and Drawing Sections". It's probably unchecked.
