Hello
I am having a problem with the absendce of edges. When I exclude a certain part from a section partisipation the edges of a part do not show up in critical areas. I have tried changing around the part's document settings and application options but with no success. I will attatch screenshots of the assembly view and drawing view after section partisipation is changed.
Thank You
Waylon
Solved by cwhetten. Go to Solution.
s the unsectioned part based on a standard (ie. Content Center) part? If so, edit the drawing view, select the Display Options tab, and under "Section Standard Parts" choose "Always."
Are these the edges you're talking about?
If so, it looks like the two parts interfere at this joint. Try turning on interference edges in the drawing view settings (double-click the view, switch to the Desplay Options tab):
Please click "Accept as Solution" if this response answers your question.
Cameron Whetten
Inventor 2014
