Inventor Forum
Section of Assembly/Part
6 REPLIES 6
129 Views, 6 Replies
I have created a Car Body in which I need a 30cm slice/section thru it. I
created 2 work plains and on them I sketched a rectangle and then
extruded/cut to leave the "slice/section" perfect in viewing it in Inventor.
The problem is the stuff I "sliced" away is still there. Is there any
command that will permately get rid of the other stuff,.,,ie...the part i
cutr away.
Jeff
6 REPLIES 6
Permanently, sure.
Use the Delete Face tool with "lump" selection.
A "lump" is a disjoined solid.
QBZ
"Jeff Dickerson" wrote in message
news:725C8867CFAC182269DA429441823604@in.WebX.maYIadrTaRb...
Inventor.
> cutr away.
> Jeff
Little confused....May I post it over on customer files and you play/with
show me.
"Quinn Zander" wrote in message
news:24D6ECB5208B4FDC3EC1C4D7EBABAA19@in.WebX.maYIadrTaRb...
> Permanently, sure.
> QBZ
I
> Inventor.
i
> > cutr away.
> > Jeff
It is under car body.
I have downloaded it, zipped it up and reposted it. It was killing OE in the unzipped
format.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
news:f163d89.2@WebX.maYIadrTaRb...
Sorry Kent.
No problem Jeff. It looks like you reposted it again though? If the one that I posted
zipped up is OK, I would like to remove the other one you posted.
Let me know.
Kent
Assistant Moderator
news:f163d89.4@WebX.maYIadrTaRb...
> Sorry Kent.
