If you are looking for Autodesk to give you more in the form of customizing this area, ytou should place this in the Inventor IdeaStation.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Styles Editor-> Select your Standard and then go to the View Preferences Tab. Select Section from View Type Drop Down. Click the Pencil. Edit the template text of how you want the Section Text to look (in your case Underline Section X-X with scale at a smaller text size). Click OK and then Done.
Ahhh the mysteries of Inventor... I have no clue on how to get those options available.
The only work-around is to manually Left Justify the text once you place your Section Line.
No problem. What I would do is post a link to this thread in the idea, then the link to the idea back here in this thread.
Hi
See the following fix, I had the same Justification issue.
