Inventor Forum
Section mark text
8 REPLIES 8
Message 1 of 9
466 Views, 8 Replies
Section mark text
I'd like to further customize the text for section titles. The first line of text "SECTION A-A" will be one size and the second line "SCALE: 1" = 1'-0"" would be a smaller size. The first line should be underlined. Please give us some options to set up some better defaults here.
8 REPLIES 8
Message 2 of 9
Cadmanto
If you are looking for Autodesk to give you more in the form of customizing this area, ytou should place this in the Inventor IdeaStation.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 9
in reply to: Cadmanto
Shoot, I thought I was already there. I thought I clicked "submit new idea". I'll move to over there now.
Message 4 of 9
Message 5 of 9
Styles Editor-> Select your Standard and then go to the View Preferences Tab.  Select Section from View Type Drop Down.  Click the Pencil.  Edit the template text of how you want the Section Text to look (in your case Underline Section X-X with scale at a smaller text size).  Click OK and then Done.
Message 6 of 9
OK, I found that...now how do I make this left justified? That option is greyed out.
Message 7 of 9
Ahhh the mysteries of Inventor... I have no clue on how to get those options available.
The only work-around is to manually Left Justify the text once you place your Section Line.
Message 8 of 9
Cadmanto
No problem.  What I would do is post a link to this thread in the idea, then the link to the idea back here in this thread.
Best Regards,
Scott McFadden
Message 9 of 9
rhasell
Hi
See the following fix, I had the same Justification issue.
http://forums.autodesk.com/t5/Inventor-General-Discussion/View-Label-Default-Position-Orientation/m-...
Reg
2024.2
Please Accept as a solution / Kudos
