When editing, are you deleting entities and adding them back in or
modifying the existing entities? If you are deleting and adding new
entities to the revolve sketch, that is why the cutting plane lines in
the IDW loose their constraints and the sections must be recreated. If
possible, when you edit try just modifying the existing entities, that
should allow constraints to be retained and the views to just update.
holt01 wrote:
> WHEN I EDIT AN EXISTING MODEL WHICH IS BASSICALLY A REVOLVED PROFILE THE
> CORRESPONDING SECTIONS ON MY IDW LOOSE THEIR CONSTRAINTS AND THUS
> REQUIRE RECREATION. IT REAALY EATS UP MY DRAFTING TIME.
Hal Gwin
Mechanical Designer
Xenogen
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4351 drivers
Dell UltraSharp 19" LCD
