Is there any way to copy section lines from one view to another? I produce designs where more than one elevation is required, but the section lines need to be duplicated in each elevation. I have tried to create a sketch in an ipt file which was then included in the assembly. The problem became apparent when I could not project this geometry to the IDW. It was visible but I could not use it to constrain the section lines to it. Thanks for your help.
Kevin Vallelunga
Macomb Engineering, Inc.
kevinv@ees.eesc.com
