Solved by JDMather. Go to Solution.
Ryan,
Soo, what is your question?
Are you talking about freezing (which is more of an Autocad term) or are you talking about suppressing or turning off the visibility? In the part or drawing? Not clear as to what exactly you are talking about, let alone what you are trying to do.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
@Cadmanto wrote:
Are you talking about freezing (which is more of an Autocad term) ....
Actually, Freezing a Notebook image has been in Inventor for as long as I can remember.
Split the part with a workplane.
Change the face color properties as desired.
Create the Note at the top level node of the part.
Freeze the image.
Return to modeling environment and Delete the Split feature or Suppress or drag the EOP above.
