Inventor Forum
Section an assembly
13 REPLIES 13
Message 1 of 14
bowen192
597 Views, 13 Replies
Section an assembly
Is there a way to section an assemlby in Inventor?
I know you can create a section view, but I want to export the sectioned model into another program.
Thanks.
13 REPLIES 13
Message 2 of 14
johnsonshiue
in reply to: bowen192
Hi! You can create assembly feature like Extrusion Cut at the assembly level to create the section. Then export the assembly as STEP or other CAD formats.
Thanks!
Software Test Engineer
Message 3 of 14
bowen192
in reply to: johnsonshiue
OK, thaks for your reply.
Is there no way to export the file as an iam?
Message 4 of 14
JDMather
An iam is a native file - simple save the file.
Does the other program you use read an iam file?
Message 5 of 14
JDMather
in reply to: JDMather
STEP does export an assembly.
Make your cut and Save as type STEP (*.stp).
What formats does your other program read?
Message 6 of 14
bowen192
The program I am importing into is Keyshot.  It can handle all Inventor files with no problems.  It even has a livelinking option for updates.
However, Keyshot has no sectioning ability, hence me trying to section the work before I export it.
Message 7 of 14
JDMather
Are you still experiencing a problem - or did you get it solved using Johnson's technique?  (you didn't mark his post as the solution)
Message 8 of 14
bowen192
Sort of.
I am waiting to see if anyone has any input to the IAM issue.
Message 9 of 14
JDMather
What issue?
Message 10 of 14
bowen192
Exporting the file as an IAM.
Message 11 of 14
JDMather
Export?
An Inventor file is a *.iam file.
Simply save the file.
Attach your assembly here (or make one up).
Message 12 of 14
bowen192
Yes, but when I import it into Keyshot the assembly is a whole assembly again.
It only works if you save as a step file.
Message 13 of 14
mrattray
You could try deriving it into a part and then using a multi-body combine operation to "cut away" the unwanted volume. Could you then use the resulting .ipt file in Keyshot (I've never heard of Keyshot)?
Mike (not Matt) Rattray
Message 14 of 14
bowen192
in reply to: mrattray
I'll give that a go.
