Inventor Forum
Second save error
15 REPLIES 15
Message 1 of 16
157 Views, 15 Replies
Second save error
Put a file in CF; kind of big (3 MB), but
probably faster than having to roll-down the EOP in all the ipt files if anyone
wants to have a look.
This is an assembly that works okay but if I save
it after it's already been saved (...did I save this yet?) it returns a
file save error. Okay that out, pick close, the save dialog comes up again and
it saves okay then. ... Huh? ... The individual subs didn't do that, only when I
get the complete assembly together does it start. The reason I know is because I
rebuilt the assembly to see if a new one would do it as well; yep it does. Are
my skates on backwards or something? Wonder if the same thing would happen to
someone else if anyone wants to give it a shot.
~Larry
15 REPLIES 15
Message 2 of 16
Hi, Larry.
There's a part that didn't get included in your zip; "ipart_spring_English
[nd=11.3 mm].ipt".
Anyway, I opened "Cartidge Sun Floating Screw-in.iam", deleted the spring
instances (two, one in top assy, one in sub), save, save. No problems or
error messages. Close, open, rebuild all, save, save. Still no probs (???).
If you want to post or email the missing ipart (and factory?, I don't often
use 'em so don't know) I'll try it again. It might be interesting to Pack n
Go the assembly to a new directory and try that assembly (?).
Jeff
"Larry Caldwell" wrote in message
news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb...
Put a file in CF; kind of big (3 MB), but probably faster than having to
roll-down the EOP in all the ipt files if anyone wants to have a look.
This is an assembly that works okay but if I save it after it's already been
saved (...did I save this yet?) it returns a file save error. Okay that out,
pick close, the save dialog comes up again and it saves okay then. ... Huh?
... The individual subs didn't do that, only when I get the complete assembly
together does it start. The reason I know is because I rebuilt the assembly to
see if a new one would do it as well; yep it does. Are my skates on backwards
or something? Wonder if the same thing would happen to someone else if anyone
~Larry
Message 3 of 16
Dang ... forgot I had that iPart spring in there. I was going to break the
link at first like I did on the Nylock because it didn't include the correct
thread but I just added the spring parameters to the table instead. I put it
in CF. Thanks Jeff. I'll try that P&G change and see if it has any effect.
~Larry
"Jeff Howard" wrote in message
news:842FA71BAF608A5E6146A982E76EA03E@in.WebX.maYIadrTaRb...
> Hi, Larry.
> [nd=11.3 mm].ipt".
often
n
> Jeff
been
out,
Huh?
assembly
assembly to
backwards
anyone
> ~Larry
Message 4 of 16
I've been bumping in to this little error message quite alot. I couldn't be
bothered about it, if I click save again afterwards IV will save the file
fine. I put it down to madness, couldn't reproduce it so it must have been
me.......
Scott
news:1B7CEE0D526836BCA75F16ECE84C1E4A@in.WebX.maYIadrTaRb...
correct
it
> ~Larry
> > Hi, Larry.
> > [nd=11.3 mm].ipt".
spring
or
> often
Pack
> n
> > Jeff
> been
> out,
> Huh?
> assembly
> assembly to
> backwards
> anyone
> > ~Larry
Message 5 of 16
I reproduced it by rebuilding the assembly, but that surely doesn't mean
it's not something I whacked.
~Larry
"Scott Stubbington" wrote in message
news:3B2C4513766D02A5B1ACF794743F0F3B@in.WebX.maYIadrTaRb...
be
been
> me.......
> Scott
the
> correct
put
> it
effect.
> > ~Larry
> > > Hi, Larry.
> > > [nd=11.3 mm].ipt".
> spring
> or
> > often
> Pack
> > n
> > > Jeff
to
already
> > been
that
> > out,
> > Huh?
> > assembly
> > assembly to
> > backwards
> > anyone
> > > ~Larry
Message 6 of 16
Tried again with the springs and still no error messages.
~Larry
Message 7 of 16
Must be something on this end, I'll go over it again. Thanks Jeff!
~Larry
news:F093E2F341E6831EB534C8A9A898D3B7@in.WebX.maYIadrTaRb...
correct
it
> ~Larry
Message 8 of 16
Is the error like the one I posted in
CF?
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
save it after it's already been saved (...did I save this yet?)
it returns a file save error. Okay that out, pick close, the save dialog
comes up again and it saves okay then. ... Huh? ... The individual subs didn't
do that, only when I get the complete assembly together does it start. The
reason I know is because I rebuilt the assembly to see if a new one would do
it as well; yep it does. Are my skates on backwards or something? Wonder if
the same thing would happen to someone else if anyone wants to give it a
shot.
~Larry
Message 9 of 16
That's the error okay. You know what it might
be?
~Larry
CF?
Sean Dotson, PE
Check the Inventor
dialog comes up again and it saves okay then. ... Huh? ... The individual
subs didn't do that, only when I get the complete assembly together does it
start. The reason I know is because I rebuilt the assembly to see if a new
one would do it as well; yep it does. Are my skates on backwards or
~Larry
Message 10 of 16
I get it with my ipart save bug all of the
time.  It seems like it's still trying to save the ipart children (and
factory <grrr>) when the second save is issued.
You have iparts in this assy right?  You
aren't seeing the ask to save the factory error are you?
Sean Dotson, PE
Check the Inventor
be?
~Larry
CF?
Sean Dotson, PE
Check the
Inventor FAQ for most common questions
I save it after it's already been saved (...did I save this yet?)
it start. The reason I know is because I rebuilt the assembly to see if a
new one would do it as well; yep it does. Are my skates on backwards or
~Larry
Message 11 of 16
Every time I save it it insist on resaving
it. That must be it; maybe the reason Jeff didn't see it, might have been
because the iPart wasn't in the Library search path. Have you tried to use the
same iPart with it in some other directory than the Library path maybe, to see
if there could be some problem with the read-only deal?
~Larry
Sean Dotson, PE
Check the Inventor
be?
~Larry
CF?
Sean Dotson, PE
Check the
if I save it after it's already been saved (...did I save this yet?)
assembly to see if a new one would do it as well; yep it does. Are my
to someone else if anyone wants to give it a shot.
~Larry
Message 12 of 16
I did set it up in a library path, but before opening the assembly I dropped
instances of each spring into a dummy assembly to create the children, so that
might have been a factor. If you kill your library paths and re-path to them
as locals does it still complain?
news:B65E0A7FBD1A6FF6774D2A1577F63CC8@in.WebX.maYIadrTaRb...
Every time I save it it insist on resaving it. That must be it; maybe the
reason Jeff didn't see it, might have been because the iPart wasn't in the
Library search path. Have you tried to use the same iPart with it in some
other directory than the Library path maybe, to see if there could be some
~Larry
Message 13 of 16
If delete the springs or place them from an off-library path, the problem
goes away; can't
make it produce the save error or bring up the repetitive save dialog.
Something must be up with that read-only directory thingy.
~Larry
news:EE17A4EF85EE9C6BD3EE968B139ECA25@in.WebX.maYIadrTaRb...
dropped
that
them
> ~Larry
Message 14 of 16
Check CF again.  Ever see this
dialogue?
I think there is a problem with the read-only
nature of libraries.  This is part of the ipart save bug that I've been
griping about for some time.  Strange things is if I change Library to YES
it will actually save the factory (a library pathed part)
BTW if I change it to a non-library path it still
asks me to save the factory....
go figure....
Sean Dotson, PE
Check the Inventor
~Larry
Sean Dotson, PE
Check the
might be?
~Larry
CF?
Sean Dotson, PE
Check the
but probably faster than having to roll-down the EOP in all the ipt
happen to someone else if anyone wants to give it a shot.
~Larry
Message 15 of 16
Yeah ... I've seen it ... I remembered that you
have been mentioning it so I figured they were on it! <G>
~Larry
dialogue?
YES it will actually save the factory (a library pathed part)
go figure....
Sean Dotson, PE
Check the Inventor
been because the iPart wasn't in the Library search path. Have you tried to
use the same iPart with it in some other directory than the Library path
maybe, to see if there could be some problem with the read-only
deal?
~Larry
(and factory <grrr>) when the second save is issued.
Sean Dotson, PE
Check the
might be?
~Larry
CF?
Sean Dotson, PE
Check the
but if I save it after it's already been saved (...did I save this
yet?) it returns a file save error. Okay that out, pick close,
the save dialog comes up again and it saves okay then. ... Huh? ...
does. Are my skates on backwards or something? Wonder if the same
shot.
~Larry
Message 16 of 16
BTW, I pulled the iPart spring from my off-path
iPart Modification directory, so it was the same iPart but it had never been in
the read-only library path since it was modified. The copy I saved to the
library path is the one that gives the problem.
~Larry
~Larry
dialogue?
still asks me to save the factory....
go figure....
Sean Dotson, PE
Check the
to use the same iPart with it in some other directory than the Library
path maybe, to see if there could be some problem with the
read-only deal?
~Larry
You aren't seeing the ask to save the factory error are
you?
Sean Dotson, PE
Check the
might be?
~Larry
CF?
Sean Dotson, PE
Check
the Inventor FAQ for most common questions
MB), but probably faster than having to roll-down the EOP in all
Huh? ... The individual subs didn't do that, only when I get the
because I rebuilt the assembly to see if a new one would do it as
if the same thing would happen to someone else if anyone wants to
give it a shot.
~Larry
