style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Larry Caldwell" <
href="mailto:lc@houston.rr.com">lc@houston.rr.com> wrote in message
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC3A9298BE94C4......
Put a file in CF; kind of big (3 MB), but
probably faster than having to roll-down the EOP in all the ipt files if
anyone wants to have a look.
This is an assembly that works okay but if I
save it after it's already been saved (...did I save this yet?)
it returns a file save error. Okay that out, pick close, the save dialog
comes up again and it saves okay then. ... Huh? ... The individual subs didn't
do that, only when I get the complete assembly together does it start. The
reason I know is because I rebuilt the assembly to see if a new one would do
it as well; yep it does. Are my skates on backwards or something? Wonder if
the same thing would happen to someone else if anyone wants to give it a
shot.
~Larry
"Sean Dotson" <sean at sdotson dot com> wrote in message
href="news:C88FB55E0E51C19F09C83B5F13CC1919@in.WebX.maYIadrTaRb">news:C88FB55E0E51C19F09C83B5F13C......
Is the error like the one I posted in
CF?
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
"Larry Caldwell" <
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC3A9298BE94......
dialog comes up again and it saves okay then. ... Huh? ... The individual
subs didn't do that, only when I get the complete assembly together does it
start. The reason I know is because I rebuilt the assembly to see if a new
one would do it as well; yep it does. Are my skates on backwards or
something? Wonder if the same thing would happen to someone else if anyone
wants to give it a shot.
~Larry
"Larry Caldwell" <
href="news:46F9D2C15C9127BA08C5687CA1CCCDB9@in.WebX.maYIadrTaRb">news:46F9D2C15C9127BA08C5687CA1C......
That's the error okay. You know what it might
be?
~Larry
href="news:C88FB55E0E51C19F09C83B5F13CC1919@in.WebX.maYIadrTaRb">news:C88FB55E0E51C19F09C83B5F1......
CF?
Sean Dotson, PE
Check the
Inventor FAQ for most common questions
"Larry Caldwell" <
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC3A9298BE......
I save it after it's already been saved (...did I save this yet?)
it start. The reason I know is because I rebuilt the assembly to see if a
new one would do it as well; yep it does. Are my skates on backwards or
~Larry
href="news:649BB9A3F0EF187C0705DC6B7DCC0C44@in.WebX.maYIadrTaRb">news:649BB9A3F0EF187C0705DC6B7DC......
I get it with my ipart save bug all of the
time. It seems like it's still trying to save the ipart children (and
factory <grrr>) when the second save is issued.
You have iparts in this assy right? You
aren't seeing the ask to save the factory error are you?
Sean Dotson, PE
Check the Inventor
"Larry Caldwell" <
href="news:46F9D2C15C9127BA08C5687CA1CCCDB9@in.WebX.maYIadrTaRb">news:46F9D2C15C9127BA08C5687CA......
be?
~Larry
href="news:C88FB55E0E51C19F09C83B5F13CC1919@in.WebX.maYIadrTaRb">news:C88FB55E0E51C19F09C83B5......
CF?
Sean Dotson, PE
Check the
"Larry Caldwell" <
message
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC3A9298......
if I save it after it's already been saved (...did I save this yet?)
individual subs didn't do that, only when I get the complete assembly
together does it start. The reason I know is because I rebuilt the
assembly to see if a new one would do it as well; yep it does. Are my
skates on backwards or something? Wonder if the same thing would happen
to someone else if anyone wants to give it a shot.
~Larry
"Larry Caldwell" <
href="news:B65E0A7FBD1A6FF6774D2A1577F63CC8@in.WebX.maYIadrTaRb">news:B65E0A7FBD1A6FF6774D2A1577F......
Every time I save it it insist on resaving
it. That must be it; maybe the reason Jeff didn't see it, might have been
because the iPart wasn't in the Library search path. Have you tried to use the
same iPart with it in some other directory than the Library path maybe, to see
if there could be some problem with the read-only deal?
~Larry
href="news:649BB9A3F0EF187C0705DC6B7DCC0C44@in.WebX.maYIadrTaRb">news:649BB9A3F0EF187C0705DC6B7......
Sean Dotson, PE
Check the
"Larry Caldwell" <
href="news:46F9D2C15C9127BA08C5687CA1CCCDB9@in.WebX.maYIadrTaRb">news:46F9D2C15C9127BA08C5687......
might be?
~Larry
href="news:C88FB55E0E51C19F09C83B5F13CC1919@in.WebX.maYIadrTaRb">news:C88FB55E0E51C19F09C83......
CF?
Sean Dotson, PE
Check the
"Larry Caldwell" <
message
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC3A92......
but probably faster than having to roll-down the EOP in all the ipt
files if anyone wants to have a look.
happen to someone else if anyone wants to give it a shot.
~Larry
href="news:8C6EF91BFE05C8F9C416207F860E2D52@in.WebX.maYIadrTaRb">news:8C6EF91BFE05C8F9C416207F860......
Check CF again. Ever see this
dialogue?
I think there is a problem with the read-only
nature of libraries. This is part of the ipart save bug that I've been
griping about for some time. Strange things is if I change Library to
YES it will actually save the factory (a library pathed part)
BTW if I change it to a non-library path it still
asks me to save the factory....
go figure....
Sean Dotson, PE
Check the Inventor
"Larry Caldwell" <
href="news:B65E0A7FBD1A6FF6774D2A1577F63CC8@in.WebX.maYIadrTaRb">news:B65E0A7FBD1A6FF6774D2A157......
been because the iPart wasn't in the Library search path. Have you tried to
use the same iPart with it in some other directory than the Library path
maybe, to see if there could be some problem with the read-only
deal?
~Larry
href="news:649BB9A3F0EF187C0705DC6B7DCC0C44@in.WebX.maYIadrTaRb">news:649BB9A3F0EF187C0705DC6......
(and factory <grrr>) when the second save is issued.
Sean Dotson, PE
Check the
"Larry Caldwell" <
message
href="news:46F9D2C15C9127BA08C5687CA1CCCDB9@in.WebX.maYIadrTaRb">news:46F9D2C15C9127BA08C56......
might be?
~Larry
href="news:C88FB55E0E51C19F09C83B5F13CC1919@in.WebX.maYIadrTaRb">news:C88FB55E0E51C19F09C......
CF?
Sean Dotson, PE
Check the
"Larry Caldwell" <
message
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC3A......
but if I save it after it's already been saved (...did I save this
yet?) it returns a file save error. Okay that out, pick close,
the save dialog comes up again and it saves okay then. ... Huh? ...
The individual subs didn't do that, only when I get the complete
assembly together does it start. The reason I know is because I
rebuilt the assembly to see if a new one would do it as well; yep it
does. Are my skates on backwards or something? Wonder if the same
shot.
~Larry
"Larry Caldwell" <
href="news:6AA47A53CC4FE9639C0EFA7D90A1D69C@in.WebX.maYIadrTaRb">news:6AA47A53CC4FE9639C0EFA7D90A......
Yeah ... I've seen it ... I remembered that you
have been mentioning it so I figured they were on it! <G>
~Larry
href="news:8C6EF91BFE05C8F9C416207F860E2D52@in.WebX.maYIadrTaRb">news:8C6EF91BFE05C8F9C416207F8......
dialogue?
still asks me to save the factory....
go figure....
Sean Dotson, PE
Check the
"Larry Caldwell" <
href="news:B65E0A7FBD1A6FF6774D2A1577F63CC8@in.WebX.maYIadrTaRb">news:B65E0A7FBD1A6FF6774D2A1......
to use the same iPart with it in some other directory than the Library
path maybe, to see if there could be some problem with the
read-only deal?
~Larry
href="news:649BB9A3F0EF187C0705DC6B7DCC0C44@in.WebX.maYIadrTaRb">news:649BB9A3F0EF187C0705D......
You aren't seeing the ask to save the factory error are
you?
Sean Dotson, PE
Check the
"Larry Caldwell" <
message
href="news:46F9D2C15C9127BA08C5687CA1CCCDB9@in.WebX.maYIadrTaRb">news:46F9D2C15C9127BA08C......
might be?
~Larry
href="news:C88FB55E0E51C19F09C83B5F13CC1919@in.WebX.maYIadrTaRb">news:C88FB55E0E51C19F0......
CF?
Sean Dotson, PE
Check
the Inventor FAQ for most common questions
"Larry Caldwell" <
message
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC......
MB), but probably faster than having to roll-down the EOP in all
the ipt files if anyone wants to have a look.
close, the save dialog comes up again and it saves okay then. ...
Huh? ... The individual subs didn't do that, only when I get the
complete assembly together does it start. The reason I know is
because I rebuilt the assembly to see if a new one would do it as
if the same thing would happen to someone else if anyone wants to
give it a shot.
~Larry
