I am attempting to sculpt a series of surfaces into a solid, and by all accounts it appears to have completed successfully (no errors, or warnings issued from inventor professional 2015). However, when the sculpt command completes the resultant solid does not show up. It is invisible. I have checked the solid bodies, and it shows it as visible, I have also checked to make sure the volume is available in the iProperties command (it shows a real positive number).
Is there any specific issues that I should look at to try to remedy this?
Thanks!
Solved by vex. Go to Solution.
Found the issue: The imported surfaces were poorly constrianed and Inventor didn't know how to fix the geometry, even with my user input. I went back and had a draftsman fix the surfaces and they directly imported as a solid; which I was attempting to do anyway.
