Sounds like you are going to the right place. Some drivers don't have the setting. Is
the printer using a driver from the OS or from the manufacturer? You might try setting up
another printer using the driver from whichever it is you aren't using, and seeing if it
has the settings. Other than that I really don't have much more to offer. Maybe someone
else that has the same printer will see this.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"kpm7" wrote in message news:f159d15.1@WebX.maYIadrTaRb...
> Kent,
> I need just a little more help. I went to my printers and selected my color Phaser 7700
printer, this is a color laser printer and I do not see anything like that under printer
properties. I also opened an IDW file and went to print and accessed the printer settings.
I did not see anything like that for the color printer settings.
> Is there someplace else I should be looking?
> Thanks for the help Ken
