Inventor Forum
Scissor Jack Assembly Design 3
9 REPLIES 9
Message 1 of 10
20112679
17867 Views, 9 Replies
Hello Everyone
I am working on a design at the moment using Inventor 2012.
It is a Scissor Jack. It has been designed to specific dimensions.
Although I am making up the majority of them as I go along.
Dim's spec's of which I must design to are as follows,
Max Height @ Open position = 250mm. (must be kept)
Min Height @ Closed position = 70mm. (must be kept)
Max width = 75mm. (must be kept)
The rest I have been taking from other designs of which I saw during my investigation.
I am having some difficulties though. As my Inventor time is still fairly new.
I have been modelling in such a way trying to adapt the open & closed position limitations with the use of constraints as my maximum & minimum limits. In doing so I have set a Drive Constraint so I can show the jack in its mechanical motion. I don't mind making any changes that will help me achieve completing it to act as it should. I believe there is still some tweaking to be done to it, but I feel the actual engineering design to be almost sound. There is an issue with the base via support arms. I cannot have the support arms moving past the floor level.
I will need to place location pins through the saddle & base connecting the arms. Finally If possible alter the gear teeth so that they interlink & coincide with each other. My screw rod also needs to work properly & turn also the nut needs to be localised in the correct position fixed on the screw rod at the end of the Side sleeve.
I have attached the assembly that  I'm now working on.
If you can offer any advice or changes to my model/assembly I would be very grateful.
Kind regards
Laurence Masson.
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: 20112679
I'll try to post the drawings for this design over the next couple of days.
Message 3 of 10
JDMather
in reply to: JDMather
Dynamic Simulation of Unknown Force to find how much force it takes to lift car with hand at different positions on the handle.
(see attached animation)
Message 4 of 10
Dante3027
Sir,you are a great designer.can u please send me the assembled part of this scissor jack so I can use it to my assignment.. please?
Message 5 of 10
Dante3027
Si,You Are A Wonderful Designer,I Need A Favour From You And I Hope You Will help Me,The Jack You Designed Was Great...Can You Send Me That Assembled Part To Me? Please?I Need To Use It In Assignment.. please?
Message 6 of 10
JDMather
in reply to: Dante3027
@Dante3027 wrote:
... so I can use it to my assignment.. please?
Here you go, let's start with this one.  (If I missed any dimensions - you can use the Measure tool.)
Let me know when you are ready for the next part.
Message 7 of 10
Sir, can u please send me the part of this scissor jack so I can learn somthing new design of jack .
Message 8 of 10
JDMather
@Anonymous wrote:
Sir, can u please send me the part of this scissor jack so I can learn somthing new ....
Yes, I can and will do that.
Attach the *.ipt of your attempt from Post #6 and I will critique and then attach next part drawing.
Message 9 of 10
JDMather
@Anonymous
How is the Base part coming along?
Message 10 of 10
JDMather
@Anonymous Are you making any progress on this first part?
