Inventor Forum
scaling
8 REPLIES 8
Message 1 of 9
drafter1411
556 Views, 8 Replies
scaling
Hello everyone, In my journey on learning inventor I ran into this problem. Can I set a drawing scale? If I want to print 1:2,
2:1 and so on? If so how?
thanks
8 REPLIES 8
Message 2 of 9
Cadmanto
in reply to: drafter1411
Can you be more specific?  Are you talking about printing or just your on screen drawing view scales?
The first view placed can have the scale set in the dialog window and that sets the drawing scale.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 9
drafter1411
HI and thanks, I want to print at a scale like 1:1 or 2:1. where do I do this?
Message 4 of 9
Cadmanto
You should see something like this in your print manager when you go to print.
SCALE.JPG  The custom selection will allow you to do the 2/1 and so on.
Best Regards,
Scott McFadden
Message 5 of 9
blair
Select the Print button, then select the "Custom" radio button. This will then allow you to set your scale factor in the dialogue box.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 6 of 9
drafter1411
this is what my 2012 shows when I click on print.
Message 7 of 9
blair
Looks like you are on XP, we haven't been on XP for at least four years. This is all I remeber for the last number of versions when hitting the print button from the top of the main header bar.
Delta Tau Chi ΔΤΧ
Message 8 of 9
Hi drafter1411,
Try it from a drawing as blair shows, and you'll see the options you're looking for. I'm not sure how you'd print to scale from a part model as you show, since the scale/zoom factor is rather unknown.
I hope this helps.
Curtis
Message 9 of 9
Cadmanto
If you are running XP, then there most definately could be an incompatibility issue.
You might want to look into upgrading because MS is stopping their support of XP in 2014
http://www.microsoft.com/en-us/windows/endofsupport.aspx
Best Regards,
Scott McFadden
