Inventor General Discussion
*Expert Elite*
JDMather
Message 21 of 31 (228 Views)
Re: Scaling Objects in Inventor
02-09-2014 02:00 PM in reply to: rdyson
Ouch!
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
dovedevic
Message 22 of 31 (227 Views)
02-09-2014 02:16 PM in reply to: JDMather
Everytime i use the Park Shrinkage, it stretches it rather than shrinks it. I tried entering negative values and it wont work that way...
*Expert Elite*
JDMather
Message 23 of 31 (214 Views)
02-09-2014 03:20 PM in reply to: dovedevic
Oops, I hadn't thought about scaling down rather than up.
You could non-uniform Scale up and then with Derived Component scale down, but this would take some calculations.
I recommend - back to the add-in, rather than trying to use the plastic part method.
dovedevic
Message 24 of 31 (211 Views)
02-09-2014 03:26 PM in reply to: JDMather
But the thing with the add-in is the fact that it wont install correctly on my system...
*Expert Elite*
JDMather
Message 25 of 31 (207 Views)
02-09-2014 03:28 PM in reply to: dovedevic
Show screen shot of your UAC setting.  (temporarily turn off your anti-virus too)
Show screen shot of your add-in manager.
dovedevic
Message 26 of 31 (197 Views)
02-09-2014 03:41 PM in reply to: JDMather
Okay here's my UAC
I reran the install file one more time (the .bat file) and...
It showed up now in the Add-Ins folder, and when I ran the program...
I get this error code. I have the latest, most up-to-date .NET framwork, so I don't know what the issue might be this time!
*Expert Elite*
JDMather
Message 27 of 31 (193 Views)
02-09-2014 03:50 PM in reply to: dovedevic
Turn UAC back on.
Reboot the computer.
Restart Inventor and try again to run the tool.
I can't read the error.
Click on that box to make sure it is the active focus.
Hit Alt Print Screen on the keyboard.
Open MS Paint and Ctrl V to paste the image of the error dialog.
Save and attach the file here.
Valued Mentor
rhasell
Message 28 of 31 (189 Views)
02-09-2014 03:59 PM in reply to: JDMather
Hi
Appoligies in advance if this has been answered, but I have not read the entire thread. I get the impression that the SDK does not want to install.
Following is an extract I wrote on my BLOG.
Hope this solves your problem
Aaaargh !!!!
I have just re-installed my work computer, a two day affair I might add. I am not complaining, it was taking me long and longer to boot my computer, average time from Logon to being able to use the machine was 7 - 10 minutes. absolute madness.
Anyway the reason for the post, it too me forever to get the Inventor SDK working, I thought I would put it here, because I struggled to find support on the web.
Note, The registry info has been extracted from the Autodesk Forums.
1 - DISABLE ANTIVURUS
2 - Perform the following registry change:
RUN Regedit.exe
Drill down to HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk
Right click on the folder and click PERMISSIONS...
Click the Advanced Button
Click the Owner Tab
Click the Change owner to: Administrators (your workstations name) and
Check mark the Replace owner on subcontainers and objects.
Click Apply
Click the Permissions Tab and double check that the Administrators have Full Control for This key and subkeys.
Click OK , Click OK , Close Regedit
Restart the computer.
3 - Install the "User Tools" SDK
(C:\Users\Public\Documents\Autodesk\Inventor \SDK)
Select the "Just Me" option
Run everything as "Administrator"
4 - run the "RegisterDrawingTools.exe"
Reg
Autodesk PDS Ultimate 2015 SP 1 Build 203
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it solves your problem.
dovedevic
Message 29 of 31 (180 Views)
02-09-2014 06:02 PM in reply to: JDMather
This is the error message I keep getting...
dovedevic
Message 30 of 31 (143 Views)
02-10-2014 04:08 PM in reply to: rhasell
So your scale and derive tool works...?
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
