Inventor Forum
Scaling a spline curve
2 REPLIES 2
DaveGadgeteer
1946 Views, 2 Replies
I started a new part, installed an image of an object (a scan) in a sketch, and traced around it using spline curves. I also included a ruler in the scan, and draw a rectangle around part of it. I hoped to scale the spline and the rectangle until the dimensions come out right, so I'd have a full-size outline to extrude from.
The rectangle scales with no problem, but the spline always fails with an error about constraints  and it not being scalable. It was made from 3 parts, but connected, and I can't see any constraints except connecting the ends. Any suggestions?
2 REPLIES 2
JDMather
in reply to: DaveGadgeteer
Why didn't you get the image to 1:1 scale in your sketch first, that is what I do.
Try converting your spline to a Sketch Block, you should then be able to scale.
Attach your file here if you can't figure it out.
PaulMunford
I agree with JD. Here's a link to how it's done:https://www.youtube.com/watch?v=LzJGWA1Ut2g&feature=youtube_gdata_player
If you don't want to start all over again, you could try turning it into a sketch block, scaling it, and then exploding the block.
Let me know if that works!
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
