Hi All,
How does one change the scale of an object in one dimension or direction? Using Inventor 2014 Professional, I drew an airfoil using splines created from a spread sheet with x and y points for the upper and lower surfaces of the foil. I wish to creat a thinner foil using the same curves scaled in the y or thickness direction by constant amount. In autocad one can make a block and change the properties of the block (it appears). How does one do the same operation in Inventor 2014. My research shows that an addin may be available. Where would I find it, how are they installed and used? Obviously, I could rescale the spead sheet points and bring in "scaled" curves but this seams like an operation a CAD package could do.
I thank you in advance for your time and assistance with this matter
Mike Snider
Solved by JDMather. Go to Solution.
funny that this post was directly under yours at the time you posted..
http://forums.autodesk.com/t5/Inventor-General/Scale-a-Part-in-one-Axis/td-p/3576068
Hi All,
I was not sure my question about scaling would be found when posted in an "old" post so I started a second. Sorry for any confussion. I followed Mr. J.D. Mather's suggestion and went to the path he indicated. I read the read me files and ran the installation bat files. How does one call up the new scaling addin? I have looked under "Environments" tab and "Tools" tab and have not gotten the interface.
Is the bow broken or is the Indian a bad shot? I suspect the latter! Perhaps there is a tutorial on addins somewhere that will help the old indian...
Thanks for all of you help and my your day be blessed!
Mike Snider
Mike when you install the add-in, make sure to close out Inventor (all instances) completely and then look to see if it is available.
Did you install with UAC temporarily disabled during the install?
Did you reboot the computer after the install?
Did you check the Add-ins Manager?
Hi JDMather,
I have made several attempts at installing the addin. All have been with Inventor 2014 closed. First I ran as administrator Install.bat located in:
C:\Users\Public\Documents\Autodesk\Inventor 2014\SDK\UserTools\DerivedPart_SP
I restarted my computer and checked Add in Manager and did not find "DerivedPart_SP." I went back two levels in the folder tree to "SDK" and ran "UserTools.msi" and still have not seen "DerivedPart_SP" in the addin manager. If it were successfully added to the manager where would the icon for this addin appear? In the sketch tool bar under modify perhaps? What is "UAC"? My user skills exceed my programming skills...
Thanks again
Mike Snider
What version of Windows are you running?
1. Click on the Windows globe in lower left of screen.
2. Type UAC
3. Click on Change UAC
Drag the slider to lowest setting and reboot computer.
Install software.
Put UAC back where is it was.
Reboot computer.
Hey JDMather!
Success! I got the "Derived Part (Scale/Position)" Add-Ins to load by turning off UAC as you showed and booting twice! The Bow is fixed! The Indian still needs training. When I go into 2d sketch and click on Add-Ins and on "Derived Part (Scale/Position)" I get a file finding page. Is there a way to use this add-in directly on the sketch or must I save / export the sketch first?
Great work on the bow!
Mike Snider
