Inventor Forum
Scale detail cross-section hatching in drawing
4 REPLIES 4
DRoam
1742 Views, 4 Replies
Is it possible to scale the cross-hatching in a detail that was created from a section view so it looks better with the scale of a detail? If the scale factor of a detail is much larger than its parent, the cross-hatching is very sparse and detracts from clarity rather than adding to it.
4 REPLIES 4
Cadmanto
in reply to: DRoam
Not sure if I quite understand what you are asking, but you can RC on the hatching and select "Edit"
If this is not what you are talking about can you please provide an image that explains it?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
DRoam
in reply to: Cadmanto
Ah, no I think that will accomplish what I need. Thanks for the tip!
LauriLink
in reply to: DRoam
Is there any Automatic way to change Hatch scale.  So if normal section view is 1:10 and if I make
detail view 1:1 then normaly Hatch scale is 1.0 but is shold be 0.1
Mark.Downes
in reply to: DRoam
Hi DRoam,
Just like to chime in. I would also like the hatch scale to be auto adjust to original scale.
I always right click edit scale
Original Section A-A hatch scale 1.0
Enlarged Detail B hatch scale 0.5 (to keep hatch scale continuity on drawing)
Maybe a request at the ideas section ??? - I would give a thumbs up Smiley Very Happy
Cheers
Mark
Inventor 2018, 3DS Max 2018, Vault 2018
