I made a new .iam, threw in a bunch of iParts, constrained a few of them and just went to save and I got this error. This error also stops it from saving so I'm not able to save it at all.
I'm not sure if this may be linked to it but when I opened the vault tab on the tree one part was red... And no I'm not saving this to Vault or using any componates from Vault, all files are stored on my local drive for this.
All parts that are added to this .iam have all been saved and closed. This is the only I currently have open.
Does anyone have a solution to this or atleast have a clue what's causing it?
Solved by ASchlaack. Go to Solution.
I renamed the file name in the .iam's model tree, which I've never seen mess with anything besides iAssembolies and rules...
I did just now delete the parts that were turned red in the Vault tree and added them back in, constrained, and then renamed them... It's now letting me save no problem and the parts were only red in the Vault tree untill I saved.
I haven't got a clue what caused it because it seems like just deleting then readding them it fixed the issue... I think this may just have been one of those random glitches but I truly don't know. You may be right and it did have something to do with references and I just did something in just the right order to screw it up. Either which way, thank you for your advice Michael.
