A simple question so one would think but I'm failing to find the answer still.
But why is it that I can only seem to save an animation in Inventor Studio (2014) as a .wmv (or Windows Media File)?
Shouldn't I have the options for saving it as other types such as an .avi or the like?
I could have sworn I was able to in past releases.....
The tuitorials say I should be able to save it as such, so where oh where is the setting that is dictating this?
Note: This animation is a cross section, not a shaded, realistic type with lighting and camera details to worry about.
In the mean time I'll keep looking and post what I find if anything here.
Solved by CelticDesignServices. Go to Solution.
FOUND IT....Duh.
Silly placement for this but one has to select the "navigate" button next to the file path on the "output" tab.
There a window will pop up and there under the "Save as type" selection will be.
Ugh
