Hello, I made an part using iLogic. This part will have some items and each item will have an especific dimension. I'm using multivalue field with excel table and it's contain all dimensions, associating each item with each dimension. When I was done the table, I would like to save each item with especific name listed in multivalue field automatically. Now, I do this manually, selecting item in multivalue field and clicking in Save Buttom that I was created with this rule:
ThisDoc.Document.SaveAs ("..\3D_Pumps\" & Tag_Pump & ".ipt", True).
I would like to do this automatically using some rule. This rule will see all items in multivalue field and save with this name and with all dimensions of this especific item. Is it possible?
Might have better luck over in the Inventor Customization forum;
http://forums.autodesk.com/t5/Inventor-Customization/bd-p/120
HTH
