Inventor Forum
Save copy as PDF doesn't work on network location
6 REPLIES 6
vmcarbonneau
492 Views, 6 Replies
I cant't save copy as PDF when I point to a nework location, It's working when I save directly on my computer.
I get a message saying : "Failed to publish DWF file." (makes no sense !)
Any idea ?
6 REPLIES 6
mrattray
in reply to: vmcarbonneau
Do you have the proper network permissions to write to this directory?
Mike (not Matt) Rattray
vmcarbonneau
in reply to: mrattray
Yes I do, I can save a dxf or dwg, I can copy manually a file
Vincent Carbonneau Martel
Directeur, Conception M?canique
www.Tecnar.com
tel: 450 461 1221 #292
fax: 450 461 0808
tlebrun
Hello, and BUMP!!!!
I just ran into this same exact problem with a co-worker.
Export to PDF, trying to save the PDF on a network drive = fail.
This co-worker is:
* An admin, with full admin rights.
* A member of a network group, and this network group has full control (read/wright)
* He can open/save any file on the network.
Exporting to PDF does work if I was to select the network drive by surfing the network PC's (using the back door) instead of selecting the mapped network drives.  EXAMPLE: (Network >NetPC04>Work Folder    vs. mapped drive-  \\NetPC04\Work Folder )
If I was to log into this PC, it works for me using the mapped network drives, so It will be hard to blame inventor. (and I've stumped my IT department with this lol)
Any thoughts?
BrandonBG
in reply to: tlebrun
Check that your translators are loaded.
In the drawing, open the TOOLS ribbon, click Add-Ins, then Translators. Look for DWF and PDF.
Brandon
tlebrun
in reply to: BrandonBG
Translater: DWG and PDF were set to "Automatic / On Demand" so I changed them to "Loaded"
Still didn't work. Good try though.
tlebrun
"DWF" not "DWG"
