Inventor General Discussion
Valued Contributor hlo
Valued Contributor
hlo
Message 1 of 4 (327 Views)
Save as - Drawing to PDF and JPG
327 Views, 3 Replies
01-08-2013 09:55 PM
Hi
I need to convert a idw drawing to PDF and JPG, when save to PDF there are no problems
but when I do it for JPG it seem to be a screen dump and not similar to the PDF I only need the drawing exact as the PDF. Is there a way for this.
Regard
Henrik
I use PDFCreator as my pdf-printer (previously found Inventor's own pdf-creation tools less than fantastic so have just stuck with a pdf-printer) - it has the ability to "print" to an image format as well as pdf, so it will create a jpg exactly the same as the pdf printout.  Might be worth giving it a try?
sam_m
Message 2 of 4 (307 Views)
Re: Save as - Drawing to PDF and JPG
01-09-2013 12:29 AM in reply to: hlo
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
Valued Contributor
hlo
Message 3 of 4 (270 Views)
01-09-2013 09:05 PM in reply to: sam_m
HI, I thanks for replaying, hopefully AutoDESK are correcting this feature in the future
Regards
Henrik
sam_m
Message 4 of 4 (259 Views)
01-10-2013 12:23 AM in reply to: hlo
dumb question - why do you mark your own answer as the solution?  it's not, so why do it?  (kinda seems like a bug/exploit in the forum software if you're able to mark your own answer as a solution)
whether it's right of wrong the jpg/image output has always been a snapshot of the screen and not linked to the print-result.  It includes the background colour plus the sheet-colour in idw environment and the xyz triad in modelling environment.  Can just use an image-editing tool to crop the desired portion of the image if it's unsuitable.
