Inventor General Discussion
New Member
Sharratt
Message 1 of 2 (214 Views)
Save a copy of drawing and model
214 Views, 1 Replies
09-10-2012 03:15 AM
I have a part (partA) and a drawing of it (drawingA)
I want to save a copy of both (partB and drawingB) and make changes to partB and drawingB will update.
To do this do I save a copy of partA first to partB and then in drawingA replace part to partB and then save a copy of drawing to drawingB
Is that the best way to do this?
Regards
Steve
*Pro
sbixler
Message 2 of 2 (208 Views)
Re: Save a copy of drawing and model
09-10-2012 04:22 AM in reply to: Sharratt
If you just have one or two to do, this is the easiest way.  If you have many to do, the Design Assistant utility is more efficient.  Or, if you are using Vault, there is a Copy Design tool that will make life easier for you.
I would modify your technique just a little, though.  Simply copy partA and drawingA to partB and drawingB.  Then open drawingB and Replace Model Reference.
You don't say which version of Inventor you are using, though.  The Replace Model Reference tool is only in the last several versions.  Before that, the same procedure applies, but you would also need to temporarily change the name of partA so that upon opening drawingB Inventor would ask you to find partA, and you choose PartB.
Hope this is clear.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
