Lester
Attached is a macro, that much of it comes straight from help. I have only done one quick
test with it, so take it for what it is worth<G>
Hopefully you should be able to use it with my iBatchrun program that you can get here
http://www.kwikmcad.com/icode/kwiktools/addins.asp--
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Lester Martin" <lester@reist.on.ca> wrote in message news:403a5081$1_2@newsprd01...
> Hi
> I have 300 plus sheet metal parts.
> What is an easy way to save the flat pattern of each .ipt in a dwg format so
> I can sent it to the plasma.
> the way I'm doing it right now is
> open each ipt file.
> click on flat pattern
> save as dwg.
> and repeat 300 plus times. ( not fun)
> Lester Martin
Attachment not added (too large): "WriteSheetMetalDwg.zip"
