@michaelmead wrote:
I tried exporting it as a DWG and opening it in AutoCad without a problem,.... I am attaching the file here....
Is it solid bodies? What does the List command report in AutoCAD?
Why are you trying to export as SAT from AutoCAD? Inventor will Import dwg files directly.
I do not see any attachments.
Right click on the filename and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Run List on the geometry in AutoCAD.
Hit F2
Attach screen shot of image.
Better yet - right click on your dwg file
SAT solid geometry is no different than any other solid geometry (as far as your problem description is concerned).
The 3D Print creates an stl file (planar faceted surface model).
