Can anybody help???
Does anybody have a Inventor part that has been created using "Frame Generator"?
I need it to test a VBA project of mine.
The more complex the better!!!!
Many thanks in advance.
Darren
I have one, but it is too large to attach here. IM me with your email and I can send it to you.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi isocam,
You can find some sample files at this link:
Once downloaded, you should find a Frame Generator assembly at:
...Inventor 20xx\Samples\Models\Weldments\Carriage
where 20xx equals the version of Inventor.
With that in mind, if you're just needing a part file that was generated from Frame Generator, attached are a few. Note that I didn't see your Inventor version listed, so the attached files are from Inventor 2010, which is the oldest version I still have at this point.
I hope this helps.
Curtis
I glossed right over that, Curtis...
Darren, do you need a part or an assembly?
Chris Benner
