Inventor General Discussion
Active Contributor
fabiogoncalves
Message 1 of 2 (116 Views)
Same part different thickness
116 Views, 1 Replies
01-29-2014 07:22 AM
Imagine that I have an part that is a simple square steel plate with Lenght*Width*Thickness.
Then in one assembly i want to add one plate with 200*200*10 and another with 200*200*5. Is it possible to have the same part with diferent dimensions? or do i really need to create an iPart. I'm having problems with my drawing manager software when i make iparts and i assemblys.....
Valued Mentor
mpatchus
Message 2 of 2 (85 Views)
Re: Same part different thickness
01-29-2014 09:40 AM in reply to: fabiogoncalves
I probably wouldn't create an iPart for just two variations of a simple plate.
I'd probably just open the plate, do a "Save As", then edit the thickness and save the part.
You could also do this in the assembly by using the "Save and Replace Component" function.
If you were going to require many different thicknesses, then I would consider making it an iPart.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
