I have 1 small assembly which will be used in 8 different locations on a large machine.I will use 8 of these small assemblies in the 1 large machine.I want the motor from this small assembly numbered from No.1 to No.8 .. Is there a technique i can use which will allow me to use this 1 small assembly but also allow me to turn on the number i require.When i place the small assembly with No.1 i can then use the same small assembly but turn off No.1 and then turn on No.2 and so on until i have 8 small assemblies numbered from No.1 to No.8
Cheers
Jason
If you want them listed as seperate parts in the BOM, then yes, you are going to have to create sub-assemblies of your bolts and name them slightly different, perhaps with ETF on the end of one and without on the other. As far as Inventor is concerened, if they have the same names, they are the same part. You can take two completely different parts and override the name in the BOM and Inventor will list them as the same part, even if the different masses and lengths cause errors. So if you want them listed seperately, the only thing to do is name them seperately. You could of course create one bolt assembly, make it an iassembly, and then leave all parameters the same except add the ETF to the name. The only difference is an iasembly allows you to pick one of two different assemblies or switch between the two. In reality though it still creates two different assemblies, just makes tracking them easier.
So the short answer 🙂 Yes, you need two seperate assemblies if you want them seperate in the BOM. If you just want them designated as ETF on the drawing then a custom symbol will work fine as I posted earlier.
Your delima is exactly why we went to the trouble of creating a bolt grip chart which I have included. If you make the bolt assembly the largest gap shown, they will work for any grip range listed for that bolt. This includes one washer.
I created a custom content center bolt and inserted it into an assembly with a standard bolt to show you the results of my suggestion. It took about two minutes. The parts list shown in the attached drawing was created by inventor and has no manual edits. The "x" in the "ES. TO FNCT." column was placed automatically as an iproperty. I think this method will accomplish what you want.
Thanks guys, that pretty much answers it!
