I'm trying to export my iam file to a 3D DWG file. When I do, I get the following error:
Runtime Error!
Program: C:\Program Files\Autodesk\Inventor 2012\Bin\Inventor.exe
This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information.
Any suggestions?
Hi herrwolf1,
Thanks for your report !
In order to clearly understand your problem, can you give me more detail about "I'm trying to export my iam file to a 3D DWG file" ? When I export an *.iam file, I only see AutoCAD DWG Files (*.dwg) in the filter dropdown, see attached image. So what's your mean about 3D DWG ?
Kevin Li
Hi herrwolf1,
Thanks for your reply!
Unfortunately I cannot reproduce this problem in my side, I notice you are using Inventor 2012, so just want to confirm with you that do you install the Inventor 2012 SP1 ? If not, download and install SP1 from http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17534725&linkID=9242019 and try it again. If still has the problem, can you send your *.iam file including its *.prt file to Hongyuan.Li@autodesk.com ? I will double check it in my side.
Kevin Li
SQA Engineer
