Solved by MingweiGao. Go to Solution.
@idesign4uti wrote:
.... I can attach or send an .ipt file if needed to diagnose. Thanks.
I only need the original part, not the mold assembly.
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
No file attachment. Try with a different browser (IE or Chrome) or you could post to Autodesk360 and then include download link here.
My problem was with the size of the file. The max file size for this site is 5MB. My file is 15.5mb. I've posted the zip file to the Autodesk 360 site. Here is the link to it: http://a360.co/1eWufwQ
OK, I have it.
BTW if you rolled up the EOP the file was only 486 kb, then zip it only 447kb. (and delete all the extraneous surface bodies)
Hello Pjk,
I took a look at your model and have some suggestion for you to create the runoff:
Hello MingweiGao,
Thanks you for your solution. This worked great! I had been close on previous attempts but, I did not realize I could use the 3D sketch to finish the Boundary Patch. This made a big difference.
My next steps are to:
1. Click on Generate Core & Cavity.
2. Click on Preview/Diagnose, when the Generate Core & Cavity window appears.
When the diagnosis is complete, a Problems List appears in the Parting Diagnostics tab of the Generate Core & Cavity window. This show a large list of missing hole patches and runoff surfaces. I will go back and fix each of these. I am having trouble patching one shutoff area. How do I patch this shutoff. I've attached a picture with the shutoff with a cloud encircling it. Does it need to be patched?
