Hi!
I have created a rule that will replace the border sheet when the sheet size will be changed, so users won't have to do it manually.
The problem is that the rule won't run when the sheet size is changed. I find that events for triggering the rules are rather few under drawing enviroment.
I thought to use "iProperty Change" event, providing I assign the SheetSize to a Custom iProperty, but the iProperty won't update automatically as well.
Any ideas what could help?
Regards
Alexandru
posting your code would help.
Also if you post ilogic or VBA questions in the Inventor Customization would get more answers.
I have an ilogic rule that changes sheet size, title block and border works when new document is started.
Where do you have your trigger set where is it in your code all this will be needed before anyone can help.
Here is the code:
kLandscapePageOrientation = 10242 kPortraitPageOrientation = 10243 CurrentOrientation = ThisApplication.ActiveDocument.ActiveSheet.Orientation If ActiveSheet.Size = "A4" And CurrentOrientation = 10243 Then ActiveSheet.Border = "A4 Portrait" End If 'A3 Portrait If ActiveSheet.Size = "A3" And CurrentOrientation = 10243 Then ActiveSheet.Border = "A3 Portrait" End If 'A3 Landscape If ActiveSheet.Size = "A3" And CurrentOrientation = 10242 Then ActiveSheet.Border = "A3 Landscape" End If 'A2 Portrait If ActiveSheet.Size = "A2" And CurrentOrientation = 10243 Then ActiveSheet.Border = "A2 Portrait" End If 'A2 Landscape If ActiveSheet.Size = "A2" And CurrentOrientation = 10242 Then ActiveSheet.Border = "A2 Landscape" End If 'A1 Portrait If ActiveSheet.Size = "A1" And CurrentOrientation = 10243 Then ActiveSheet.Border = "A1 Portrait" End If 'A1 Landscape If ActiveSheet.Size = "A1" And CurrentOrientation = 10242 Then ActiveSheet.Border = "A1 Landscape" End If 'A0 Portrait If ActiveSheet.Size = "A0" And CurrentOrientation = 10243 Then ActiveSheet.Border = "A0 Portrait" End If 'A0 Landscape If ActiveSheet.Size = "A0" And CurrentOrientation = 10242 Then ActiveSheet.Border = "A0 Landscape" End If
I can run it with itrigger, but that's not the idea, because other users don't use ilogic. I have lots of ilogic rules in different inventor files that other users don't even know about them, those rules run in background without interacting with the designers.. Most of them won't like the idea of pressing a button (itrigger), they are not used with ilogic things. I just want it to be automatically done by Inventor.
The trigger is silent they will be prompt at the start and they will pick option the tigger makes it happen but they don't have to do anything but pick.
Make it ask them when new template is used.
My code is not what you are after but you may get the idea. My ilogic is used to ask what sheet size to use all are in landscape and also changes the styles.
But you may get the idea what to do.
In the fx you will make a list of options..
trigger=iTrigger0 Dim drawingDoc as DrawingDocument = ThisDoc.Document Dim stylesMan As DrawingStylesManager = drawingDoc.StylesManager Trace.WriteLine(" --- Active drawing standard = " & stylesMan.ActiveStandardStyle.Name ) 'Pick Sheet Size Sheet_Size= InputListBox("Select Sheet Size", MultiValue.List("Sheet_Size"), Sheet_Size, Title := "Sheet Size", ListName := "Choose Sheet Size") 'A size If Sheet_Size = "A (8 1/2 X 11)" Then ActiveSheet.ChangeSize("A", MoveBorderItems := True) ActiveSheet.TitleBlock = "your info" ActiveSheet.Border = "your info" stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("your info") 'B size ElseIf Sheet_Size = "B (11 X 17)" Then ActiveSheet.ChangeSize("B", MoveBorderItems := True) ActiveSheet.TitleBlock = "your info" ActiveSheet.Border = "your info" stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("your info") 'C size ElseIf Sheet_Size = "C (17 X 22)" Then ActiveSheet.ChangeSize("C", MoveBorderItems := True) ActiveSheet.TitleBlock = "your info" ActiveSheet.Border = "your info" stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("your info") 'D size ElseIf Sheet_Size = "D (22 X 34)" Then ActiveSheet.ChangeSize("D", MoveBorderItems := True) ActiveSheet.TitleBlock = "your info" ActiveSheet.Border = "your info" stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("your info") 'E size ElseIf Sheet_Size = "E (34 X 44)" Then ActiveSheet.ChangeSize("E", MoveBorderItems := True) ActiveSheet.TitleBlock = "your info" ActiveSheet.Border = "your info" stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("your info") End If Trace.WriteLine(" --- Active drawing standard = " & stylesMan.ActiveStandardStyle.Name ) 'update all InventorVb.DocumentUpdate() 'zoom all ThisApplication.ActiveView.Fit
