every time i save a drawing this rule error keeps coming up im not sure how to make it go away im usng Iv 2011 routed systems
Inventor is looking in the folder(s) you set up to store external rules. If your rule is not in one of those folders, I would assume you'll get the message you're seeing. To tell Inventor where to look for external rules, go to Tools > Options > iLogic Configuration. There you can specify a folder (or a bunch of different folders) where Inventor looks for iLogic rules, as well as what file extensions and where the iLogic add-in is located.
Hint: image attachments are much smaller in formats other than .bmp; try saving as .png or .jpg.
