Inventor General Discussion
Member
mklassen78
Message 1 of 17 (644 Views)
Rubber Track Design
644 Views, 16 Replies
01-09-2013 07:17 PM
Trying to model a track but i have it in more of a triangular orientation then an ovel like this sample picture. Any advice on how to pattern the tread and inner lug around any shape i desire? I have tried making an extrusion on one of the flat faces and then patterning it around but it keeps the lug in the same orientation and does not follow the contour nicely. Any advice for me
I made this simple track with the emboss feature. First created a sketch with a pattern of the profile, dimensions linked to the geometry of the basic track to match the right size. Then emboss the sketch first on the straight part, then reused the sketch and emboss this on the curved part of the track with wrap to face option on. Last step, circular pattern the 2 embosses to the other sides. Check the attached ipt (2012) to see how i did it.
Rob.
Valued Contributor
streharg
Message 2 of 17 (632 Views)
Re: Rubber Track Design
01-09-2013 11:36 PM in reply to: mklassen78
You can do rectangular pattern in part enviroment along choosen curve, and set orientation to direction1. This should work.
I hope that's what you're looking for.
Greg
Factory design suite 2013 premium
Some old workstation ...
Fancy HP LCD
:smileyhappy:
JDMather
Message 3 of 17 (614 Views)
01-10-2013 04:42 AM in reply to: mklassen78
mklassen78 wrote:
Trying to model a track but i have it in more of a triangular orientation . Any advice for me?
See this document pg 16
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
mklassen78
Message 4 of 17 (562 Views)
01-10-2013 06:19 PM in reply to: JDMather
Thank you for your replies! JDMather that does work to pattern around and i can get it to follow the contour i want but it leaves a gap between the "treads" as it is patterned around a curve. It does not keep tangent. Any solution to that?
JDMather
Message 5 of 17 (559 Views)
01-10-2013 06:55 PM in reply to: mklassen78
Attach your ipt file here.
Member
mklassen78
Message 6 of 17 (549 Views)
01-10-2013 08:21 PM in reply to: mklassen78
Hope this helps more
JDMather
Message 7 of 17 (534 Views)
01-11-2013 04:47 AM in reply to: mklassen78
I don't see a pattern in the file you attached?
When I attach my solution the sketch for the tread will be on the XY plane.
The extrusion for the belt will initially be a surface body and then Thicken after the Pattern of the treads.
Member
mklassen78
Message 8 of 17 (519 Views)
01-11-2013 08:07 AM in reply to: mklassen78
That is why im on this forum, It will not allow me to pattern and keep tangency, It just gives an error. The lugs i want to pattern are in the file though.
JDMather
Message 9 of 17 (515 Views)
01-11-2013 08:33 AM in reply to: mklassen78
mklassen78 wrote:
.... It just gives an error.
Post screen shot of error.
JDMather
Message 10 of 17 (508 Views)
01-11-2013 09:07 AM in reply to: JDMather
I experimented with this one a bit more.
It is going to be a bit more work than I originally thought.
Because the tread cleats bend around the curves - my attempt would be with patterned-trimmed surfaces, thicken and trim again.
