Im having a problem with the RSS feeds, they come up but when i click on them nothing happens. any ideas?
Hello
Can you please take a look a that solution
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=3332410&linkID=9240617
Please also take a look at the logs files under C:\Documents and Settings\t_massp\Application Data\Autodesk\WebServices
It will help you understand more.
That kind of behaviour comes mostly when some Proxy Server or Firewall settings are blocking the connection.
tried checkign to see if it was the firewall, even turned it off and still nothing. I also tried the link you sent and still nothing, plan B?
