Albert,
How many hours do they put on race cars?... I don't think they race on the
North Slope, either.
4130 is good stuff, but only as good as the welds.Welds on Racecar frames
are inspected with a comparator (ask your machinest). NO undercut on a 4130
weld is too much.
Only 16 man hours?? are you sure? What about down the line in assembly and
even field mods?
Your salesman is smoking crack. Perhaps he would like to be the one to mount
"something" (storage box, hangar- anything) to a Cat in the field with a
drill and welder.
I have never ever seen in "real" applications round structual NOT crack.
The easiest way to explain to the salesman (he's in the bathroom getting a
hit) it take him out to the shop and grab a joint of 2x3x.125 rec tube off
the rack and toss it at him noting how "stiff" it is.
Then grab a joint of 3/4 Cold Roll shaft and toss it to him noting the
"spagetti" properties.
Then go back to work.
QBZ
"Albert Allen"
wrote in message
news:FFDD17FA47507A26A21B3039689F73F7@in.WebX.maYIadrTaRb...
> A simple yet complex question for all you P.E.'s or anyone else that want
to
> give it a stab..........Pound for pound which is stronger for a vehicle
> frame, round or square tube?
> Here is the situation:
> We have always built square tube frames for our Sno-Cat's but recently
have
> been working with 4130 round tube frames. We are trying to get vehicle
> weights down and although we have saved about 100 pounds using round tube
> over square (no big deal on a 7300 pound machine) we have also added 16
man
> hours per frame in the process and we are starting to see some slight
joint
> cracking in the round tube frames (which we have never had with square)
> As you can tell I am biased toward the square tube frames but as one of
our
> salesmen pointed out, "all the race cars use round tube frames and they
have
> no problems"
> Any advice would be greatly appreciated and pardon the non Inventor
related
> subject but this is where all the brains are
> Thanks
