Good Day, Just want to learn on how to make this Clamp Rod to Clamp Base Spacer Turn relationship.
this is from the Clamp Project on this site: Inventor Wizard, The Clamp Lever is turning or rotating the clamp rod into the Clamp Base Spacer but I could not simulate the Thread or the Screw motion if that is the term, or the 1 or 1/2 turn of the Clamp Rod to 1 Pitch movement, plus I can't seem to put the Rod inside the Clamp Base Spacer hole when the Contact Solver is ON, maybe modeling issue on my part.
Attached is my assembly, appreciate any help.
Bump.
Just moving this back to the top.
I intended to get to it earlier, but busy for now.
Maybe someone else can show the solution (you do not need or want Contact Sets).
