When rotating a large assembly in 2013 half the model disappears until I stop, is there a setting to turn this off.
Thanks for the help........
Solved by NicolasXu. Go to Solution.
Hi stephen,
You may adjust the Display setting from Tools->Application Options->Display tab. Particularly, View transition time, Minimum frame rate.
Nicolas
