Sorry, misunderstood.... just add a construction line to one edge of
the text box with collinear constrant. Then rotate... it will ask you if
you want to remove the constraint... say no.
Dennis Jeffrey
Chris Breidenbaugh wrote:
> No luck.
> Here's what I have done.
> I created a work plane. Then created a new sketch on the work plane. I then
> use the text tool to add a part number. But I cannot get any thing to come up
> prompting me to rotate the text. The menu that comes up does not include a
> Rotate 90 CW or Rotate 90 CCW. Even tried using the rotate tool from the
> sketch menu.
> Dennis Jeffrey wrote:
>>Right click on the origin grip at the corner, the menu will appear.
>>Dennis
>>>I am trying, unsuccessfully to rotate text.
>>>The help system say to select the text note, then right click to display
>>>the menu. Then chose Rotate 90 CW or CCW to rotate the text.
>>>I can not get the menu to say Rotate 90 CW or CCW. I have tried while
>>>sketch was in edit mode and finished.
>>>Any help greatly appreciated.
>>>Chris
