Inventor Forum
Rotate text in a sketch
6 REPLIES 6
Closterman
7560 Views, 6 Replies
hy I can't rotate my text in the sketch ?? If I right click on the text (duting the a sketch edit) the "rotate 90" and "text box" option are gray.
If I edit my text, I'n not able to click on the rotation box, normaly for that !! It's a bug or I make something wrong. !!
6 REPLIES 6
MattH
in reply to: Closterman
You could try my iNudge addin available from
http://www.mcadforums.com/forums/viewtopic.php?t=4778
Regards
MattH
mcgyvr
when in edit sketch mode right click on the text and uncheck the "text box"..then right click again and your rotate options should be available then.
Closterman
AAHH !!! Your right !! Thank a lot !
JDMather
Dimension the text box angle to any angle.
Tip 40 & 41
http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
hellreaver
in reply to: mcgyvr
Thanks!!
johnsonshiue
in reply to: hellreaver
Hi! Another frequently overlooked workflow is to use Sketch Block. Right-click on Sketch Ribbon -> Show Panel -> check "Layout." Create a sketch block for the sketch text. Then it will be very easy to rotate the block as a rigid object.
Many thanks!
Software Test Engineer
