Inventor Forum
Rotate "Break" view - not horizontal or vertical
2 REPLIES 2
hagiographa
754 Views, 2 Replies
I can only get horizontal or vertical 'orientation' in "Break" view.
How do I rotate it to say 60degrees to use on an iso view?
Tags (2)
2 REPLIES 2
BLHDrafting
in reply to: hagiographa
I don't think you can put a break on an isometric view.
If you put the break on the base view and then project that view to the iso then the break is added. See picture.
Edit : you can place a break on an isometric view but the output is dodgy.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
blair
As posted you can't, but you can suppress the broken base view so all you would see is the single ISO broken view.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
