Inventor Forum
Rotate emboss/engraved text
5 REPLIES 5
danderson
405 Views, 5 Replies
Is there a way to rotate text for engraving. The rotate command in sketch tools won't allow me to select the text to rotate it. The text aways comes in along the x axis.
3ds Dos 3 -3DS MAX 2015
I7-4820K
GTX 770 4 mb
16 Mb Ram
512 Gb SSD, 1.5 Tb Raid 0
5 REPLIES 5
in reply to: danderson
grab a corner, and rotate, then add a angle dim from a edge to something else.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"danderson" wrote in message news:f14c25e.-1@WebX.maYIadrTaRb...
danderson
Thanks for quick reply. But when I grabbed the corner it just keeps resizing the text box.
I7-4820K
GTX 770 4 mb
16 Mb Ram
Try adding an angled construction line, use a
ground constraint or dim to lock it down then add a
collinear/parallel/whatever constraint and the text should
comply.
~Larry
box.
Use the rotating tool inside the text dialog box.
I don't think that's available in sketch text is
it?
Use
