Inventor Forum
Rotate a drawing view using iLogic
2 REPLIES 2
jddickson
2101 Views, 2 Replies
Is it possible to rotate a drawing view using iLogic? If anyone out there can help me I would appreciate it.
2 REPLIES 2
Hi  jddickson,
Here's a quick example:
Dim oApp As Application
oApp  = ThisApplication
Dim oActiveSheet As Sheet
oActiveSheet = oApp.ActiveDocument.Activesheet
Dim oBaseView As DrawingView
oBaseView = oActiveSheet.DrawingViews.Item(1)
'rotate by 45 degrees (converted from Radians)
'True = Clockwise
oBaseView.RotateByAngle(45*(PI / 180), True)
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Thank you very much. That’s exactly what I needed.
